Wall schedules/quantities by level
7 REPLIES 7
Message 1 of 8
7632 Views, 7 Replies
I wonder why the schedule parameter "level" doesnt exist in the list of available fields when I try to list the walls and columns in my project (two different schedules).
For all other objekts in the project (e.g. floors, windows and doors) I can choose "level" as a field and sort objects by level.
The walls are modeled as seperate objects for each floor.
7 REPLIES 7
Message 2 of 8
aghis_no
I never understood why, but this is not possible… just reed this blog article and
wait for the addin by case http://autodesk-revit.blogspot.fr/2012/11/cant-schedule-wall-constraint-part-2.html
Message 3 of 8
msalem
We were discussing this few days ago, and what we came up with here in office is pretty simple and manual entry. Just open each level, select all walls visible in view & change the value of comments or any other custom property to "Level x".
Tags (2)
Message 4 of 8
Va3ilem
Years away ....
Use Filter by Base Constraint
Message 5 of 8
chrisplyler
Walls and Columns both have the parameter Base Constraint. It should substitute for your desired Level info in most cases. If you schedule it, you can even change the name of the schedule column header to "Level" if you want.
Message 6 of 8
Zombie thread. It could be that the question was asked for an older version, when Base Constraint Parameter was not available in a wall schedule.
Message 7 of 8
chrisplyler
in reply to: ToanDN
Oh. I'm too stupid to look at the dates of posts.
How's your bike???
Message 8 of 8
in reply to: chrisplyler
Still ride-able.  With duct tapes and zip ties everywhere of course.
