Revit Architecture
Distinguished Contributor
1 Kudo
Post 1 of 3
Wall roof joint
506 Views, 2 Replies
09-21-2013 03:01 AM
I've attached a picture of a wall roof joint, where I would like the concrete core of the roof to meet the concrete core of the wall. I know I could do this view-specifically by "Cut Profile" tool. However, my question is: Is there any way to do this in actual 3D? So that the joint would look the same also in other sections?
363 Kudos
Post 2 of 3
Re: Wall roof joint
09-21-2013 06:21 AM in reply to: elina.hyvamaki
If the materials are the same, they join by simply using "Join Geometry". Even if it is floor to wall, or roof to wall, they join.
If that does not give you exactly what you need, you might considering using "parts" or, as a last resource, creating the components of roof, floor, or wall as individual elements.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
1 Kudo
Post 3 of 3
Re: Wall roof joint
09-22-2013 04:53 AM in reply to: elina.hyvamaki
Thanks for your answer! It's great to know about the "Parts" tool, because I can use that, if "Join Geometry" doesn't work. I did try the "Join Geometry" tool before posting my question, but it seems like a window interferes with the joint, so that it doesn't do it right, if the window is not situated higher than the roof slab. In the file attached, the joint on the left side is correct, but the ones on the left are incorrect.
