For niches, I'd do a niche family for small niches. For larger ones I'd do 3
walls. The right side of the niche. The left side. Then the soffit wall
above. This allows you to use the wall join tool with "square off" Or make
an opening family using a generic wall hosted family. This will let you cut
intricate voids in the wall.
"Jenb" wrote in message
news:7794888.1103058699247.JavaMail.jive@jiveforum1.autodesk.com...
> Is there a way that one can edit the profile of a wall in plan view? I
often have angled walls joining with straight ones and Revit then joins them
in a structured way while I would like to keep a corner on the one wall. I
also have niches with angles sides and if I edit profile in elevation view
Revit cuts these sides straight. Does someone know of a better way than to
create a tiny extrusion or sweep?
