I would like to create a brick wall with pilasters... I can start this by creating a column type and putting it in front of the brick wall type. However, when I go to add a wall sweep....it does not follow around the pilaster...as I expected. Is there a way to create pilasters so that the wall section believes it is part of the actual wall....and thus the wall sweeps would work as needed?
Jim
