So I am making a constructing a building on Revit and i need to put in paneling
I made it under the Wall template and my first problem is the window wont go through the wall you can see it highlighted but it just wont go through how can i change this.
Next i need to put in 3 different types of walls i need wood paneling for the bottom half but for the top half i need Slot board how do i split this up.
next i need to know of a place i can find all these walls because i looked at revitcity and it didnt help me at all.
i tried to custom make the walls and like i said it just didnt work
this is a huge project for me
this is my starting point of career please help!!!!
Hi. A bit of explanation first.
1- Walls are system families and as such cannot be created or deleted.
2- Nevertheless you can create as many of these as you would need.
3- There are 3 types of walls: Basic walls, Stached walls, Curtain walls.
4- Basic walls are walls that are composed of as many layers as you would need.
Select wall, edit type, edit structure, modify to suit your needs.
5- Stacked walls are walls that are composed of a series of basic walls stacked on top of each other.
Select wall, edit type, edit structure, add the basic walls that you have created.
Remember that one of the stacked layers will be variable to account for the floor levels.
Regards.
Just as a tip -- you never want to simply edit an existing wall type. When you go into editing mode there is an option to duplicate that wall type, after which you can rename it and then edit the duplicate version. This preserves the existing wall type definition.
Your Name
