Hi
I'd like to know if somebody found a solution to perform a wall opening quantification. I'd like to know how many openings are in each walls and their sizes.
Because the only way I found is to replace all the openings by a (simple) window family (which is quite long) and then make a window quantification.
Thanks for your feedbacks!
Solved by Rafal.Gaweda. Go to Solution.
Try this tool:
https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3awallopeni...
