wall openings quantification
3 REPLIES 3
sabatierae
269 Views, 3 Replies
Hi
I'd like to know if somebody found a solution to perform a wall opening quantification. I'd like to know how many openings are in each walls and their sizes.
Because the only way I found is to replace all the openings by a (simple) window family (which is quite long) and then make a window quantification.
Thanks for your feedbacks!
3 REPLIES 3
Rafal.Gaweda
in reply to: sabatierae
sabatierae
in reply to: Rafal.Gaweda
I've tried it but I want something like that..
Rafal.Gaweda
So try programming by your own.
You may try Dynamo also
Rafal Gaweda
