Hi, Please tell me how can I get this kind of wall opening? See attachment
Solved by ccollins. Go to Solution.
There are a couple of ways:
1. Create an in-place Void family and use Cut Gemoetry. You could also create a Family outside the project, create a rectangular Void extrusion, making sure it extends past the thickness of the wall you need to cut, and load it into the project.
2. Use the Wall Opening Tool
3. Edit the Profile of the Wall, and draw the opening in sketch mode, then finish sketch.
4. Open a window family, save-as, name it Opening, delete all geometry--leaving only the Opening Cut
and place it in the wall like a window.
cheers
Thank you very much!
I want the bottom of opening is slope. See opening section in attachment. Thank you!
The sloped sill can be done with the Void family, and use Cut geometry.
