wall of different finishes
1 REPLY 1
milaszka
250 Views, 1 Reply
Hello everyone. I just started new project in Revit (beginner) and I have a wall which has different finishes. At ground level up to first brickwork which from first floor is replaced by blockwork and render.
How do I do it? I tried split regions etc but don't know
the solution in the end
1 REPLY 1
cbcarch
in reply to: milaszka
There are a few methods:
1. Split Face-Paint; good for quick stidies--but Wall Edits may delete split faces--so not the best solution.
2. Stacked Walls--combine various Wall Types together into a Stacked Wall, each having different Material designations, and heights.
3. Parts--Divide; Create Parts, then create divisions/areas and apply various Materials in a single Wall. Parts may be used to "peel back" the individual "layers" of a compound wall as well. You can even create a 3D View, lock it--and anotate the different Materials using Tags.
Good luck!
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
