Hello!
Have you noticed, that walls are in plan view mostly drawn by turquoise lines?
I tried to change the colour, but did not manage?
It is illustrated in attachment, what I mean.
In: Manage - Object styles - walls, list I did not found a type that matches with that turquoise line type.
Notice that I have changed the line type: Wall - Common Edges, to magenta. So that you can see that one line type is still turquoise.
So, what is that line type and how can it be changed?
Thank you!
Matti Kettunen 🙂
Solved by kettuma. Go to Solution.
Solved by kathryn.langan. Go to Solution.
Are the Host Layers overriden? To see what I mean, go into Visibility/Graphics. Near the bottom right, next to the Cut Line Styles checkbox, click Edit. Are any layers in the dialog set to display turquoise?
Hi!
Thanx again Katie!
Problem solved!
It was so simple... ;-D
I have sometimes something wrong with my eyes, I think! ;-D
Matti Kettunen
No problem - glad to help!
