Hello, I have a problem with joining some walls.
Here I am attaching an example situation of what I am talking about.
Here, as you see, I have 3 different wall. The green one is a structural
wall and the white ones are regular wall.
I first draw the green one by using a wall type than by using another wall
type I draw the white ones.
At that point revit joins them together in a way that I don't want.
The example here is a screen capture from AutoCAD. And my question is, how
can I create walls looking like this.
I tried to use edit cut profile tool but I was not successful. Ofcourse I
can fake the view with that tool, but I don't want to fake it, since I will
be seeing in perspectives, and views, etc.
If possible I would appreciate an example revit file (I have version 5)
thank you very much.
Bolkar
