Is there a way to turn off all wall joins before laying out walls?
I know this can be done by individually selecting each wall intersection and using the "disallow" on the Edit Wall join tool but it's kind of a pain to have to do it this way....
No. Views have a parameter named as "Wall join display". By default, that parameter is set to "Clean all wall joins". The only other option is "Clean same type wall joins". There is no "Do not clean any wall joins" option.
