I was trying to add a brick soldier course to a wall type using the sweep box in the edit assembly box while I had the vertical section preview on. I am now getting an error that I can't seem to get rid of. It says "wall is shorter than minimum height allowed by its type. It is and must be . It next tells me a serious error occurred and asks if I want to save a recovery file. Again I don't know what I did because I now get another error that says file has the incorrect schema. I can't seem to save the file. Any help would be much appreciated.
I am getting the same error with wall sweeps in a CMU wall. Any help out there?
Was there even a solution to this problem?
I have the same issues and there is NOTHING I can do to the walls...delete, change styles, this includes all adjoining walls.
If you can edit the wall type, try remove the sweep. Or, change the sweep profile to something else.
