Create an in-place family wall.
In the Modeling tab, click Create, the select Wall, and give it a name.
This will put you into in-place family mode. From the Tools bar, select
Solid, the pick Sweep from the resulting pop-up window. This will take you
into Sketch mode for defining the sweep. Select Pick Path from the Tools,
then select the spline line you already have drawn. Click Sketch Profile in
the Tools, and sketch the profile of the wall. You may need to switch views
and/or turn on the work plane grid to draw this. You will see a set of Ref
Planes with a red dot at the intersection, this is the origin point, and the
Ref planes show the axis you are working in.
When done, click Finish Sweep, then Finsih Family. You should now see a
spline-curved wall.
HTH,
Scott
"Jeff Hanson" wrote in message
news:40742f77_1@newsprd01...
> Is there a way to create a wall from line geometry? We have a spline
layed
> out in the drawing and would like to have a wall created following the
path
> of the spline. Can we do this, and if so what are the steps?
> Thanks, Jeff Hanson
