wall end condition?
4 REPLIES 4
1435 Views, 4 Replies
wall end condition?
So I have a curved wall meeting up with a curved/angled curtain wall system.
What is the trick to angle out the end of the wall so it will butt up with
the curtain wall?
thanks
4 REPLIES 4
Go to the elevation that shows the side of masonry wall, click on the wall
then in the ribbon click edit profile, once in edit mode draw a line at the
same angle of the curtain wall, trim/extend the upper and lower lines to the
newly created line, erase the vertical line representing the old wall edge
and you are done .
"Dustin" wrote in message
news:6398553@discussion.autodesk.com...
> system. What is the trick to angle out the end of the wall so it will butt
> up with the curtain wall?
> thanks
tried that and I do not get the edit profile option with the curved brick
wall
"cdv" wrote in message
news:6398543@discussion.autodesk.com...
and you are done .
> thanks
> wall
Make the masonry wall longer, use an in-place void to remove the portion
below the curtain wall.
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
> and you are done .
will that work if the face plane of the curtain wall is curved? You
wouldn't be able to use a line for the trim/extend...
Dave - DDP
Acad 2011 and Revit 2011
Win 7 Pro 64 bit
Intel I7-860 @2.8GHz
12GB DDR3 RAM
GeForce GTX260
