Wall cuts became transparent
2 REPLIES 2
andrea.paleari
480 Views, 2 Replies
Hi. I've done a radiator family based on plumbing fixture category based on walls that create a recess thrue a void extrusion that cuts the wall.
The problem is that the wall beyond the recess became partially transparent.
Why? Can anyone help me?
Thanks. Andrea
2 REPLIES 2
L.Maas
in reply to: andrea.paleari
I do not see the behaviour you describe. I loaded your radiator in a project.
Therefore I expect it has to do something with your walls (materials?) or maybe your graphics card.
-Try to load you radiator in a new project with a different wall type and see if your observe the same behaviour.
-Deselect hardware acellaration for your grpahics cards ("Options", "Graphics", deselect "Use Hardware Accelearation")
Otherwise upload (part of) your project so that we can have a look.
Louis
Please mention Revit version, especially when uploading Revit files.
andrea.paleari
in reply to: L.Maas
Thanks.
I've tryed the family in a new project and it works.
Disabling hardware acelleration don't provide any results.
Changing wall material doesn't correct the problem.
Renderings works in intended way (without transparency).
