Exist a way to Attach the top of the wall in a element that is not a floor or roof.
I have a wall under a stair and i want to make de top of the with a slope.
thanks!!!
Hi
Attach the wall with stairs allowing you to do that, but you can use the following method.
1 - Plan View Ref Plan and draw a name to your propertise window.
2 - Select the Component Model-In place and Wall Options window, choose a name and press Ok to enter your family.
3 - Ref Plane to a Set Voied Extrusion method and depth to draw Profile.
4 - Now, Profile, Cut drawn from Wall least now.
I hope to help you
Some additional info:
I did a search for {Attach wall to stairs Revit} (without the brackets) and found the following threads on this topic:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/join-attached-wall-to-stairs/td-p/3280187
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Attach-wall-to-stairs/td-p/1271079
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Attaching-wall-to-stairs/td-p/2428879
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/walls-and-stairs-attach-join/td-p/2332168
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Attach-wall-to-underside-of-Stair/td-p/103...
