Revit Architecture
Valued Contributor
kwihae
Message 1 of 2 (886 Views)
Voids to cut host wall in window family
886 Views, 1 Replies
02-16-2012 07:46 AM
I would like to cut a void into the wall of a host window family.
When I place a void in the family, it does not cut thought the wall.
I tried making the void on a plane perpendicular and parallel to the wall plane.  I dont know if this has anything to do with how voids work.  But its not working.
I also dont have an 'opening' element in the window family.
help!
ccollins
Message 2 of 2 (883 Views)
Re: Voids to cut host wall in window family
02-16-2012 08:10 AM in reply to: kwihae
Inside the project, try using Cut Geometry--select the wall, then the window family.
Does this work?
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
