Voids in nested families issue
13 REPLIES 13
Message 1 of 14
alex60
990 Views, 13 Replies
Hi every one, I am doing a window nested family with two windows that have three voids to performe the wrapping of the stucco layer and the gypsum layer independently, but in the nested family I get a wall sleeve between both windows. I have used voids with parameters in the nested family, but when inserted in the projects the voids don't cut anything. See the images. Please, any help will be very helpfull.
Ales
13 REPLIES 13
Message 2 of 14
ccollins
in reply to: alex60
You may need to use Cut Geometry to make the voids cut the host inside the Project.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Message 3 of 14
alex60
in reply to: ccollins
Hi Cliff, the issue is that when we use the cut command in the nested family works fine the voids, but in the project we receive an error with the voids not cutting anything.
Thanks, Alex
Message 4 of 14
Jason_S
cheers
I agree with ccollins.  That has been my experience when using voids in nested families.  Make sure the void is cutting the wall in the nested family.
Message 5 of 14
alex60
in reply to: Jason_S
Thank you all, but in a recent research in this forum I found out an answer that I belive could solve the problem. I am using the voids in the nested family, and control their lengths with a parameters created in the nested family. The issue is when inserted in the project the voids do not work fine. I have read that I can not control the voids in the nested family with parameters created in the nested family, they must be created in the host family.
Any help will be helpfull.
Thanks, Alex
Message 6 of 14
ccollins
in reply to: alex60
Are the nested familes Shared?
Do you have any Shared Parameters or Project Parameters?
If you load the host family, which has a nested family containing voids in it, into the Project, then use Cut Geometry,
does it cut the wall?
cheers
Cliff B. Collins
St. Louis, MO
Message 7 of 14
alex60
We have the nested family with voids and instance parameters to control the void height, we use the cut command and works fine in the nested family, but when inserted in the project the voids do not cut any thing. That's the problem.
Alex
Message 8 of 14
ccollins
in reply to: alex60
Can you post the family?
cheers
Cliff B. Collins
St. Louis, MO
Message 9 of 14
alex60
I am trying but it 1.8 kb and is not loadable. I zip it but also has 1.7 kb so if you any idea to compact the folder I will do it.
Thanks, Alex
Message 10 of 14
ccollins
in reply to: alex60
Try purging the family? Maybe file size will go down a little.
Cliff B. Collins
St. Louis, MO
Message 11 of 14
alex60
in reply to: alex60
I am posting two images of the nested family that works fine, and the error when the nested family is inserted in the project.
Thanks, Alex
Message 12 of 14
alex60
in reply to: alex60
Reviewing the problem, I realized that one of the voids that cut out the wall become invisible in the family and there is no way to selected after we use the cut command. Any idea about this problem. I purged the family and did not lower the kbytes.
Thanks, Alex
Message 13 of 14
ccollins
in reply to: alex60
see attached.
Cliff B. Collins
St. Louis, MO
Message 14 of 14
alex60
I just did it, but no result. We obtain the same issue.
Thanks, Alex
Rail Community
