Revit Architecture
LisaDrago
Message 1 of 3 (370 Views)
Void still showing!?
370 Views, 2 Replies
02-24-2011 04:19 PM
So I have a family that i have placed a void in... typically once the void cuts an object it goes away...
for some reason - in this file it isn't.. i have attached twom images - one with the void - one without.
does anyone know what is happening?
Thank you.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Employee
ryan.duell
Message 2 of 3 (342 Views)
Re: Void still showing!?
02-25-2011 07:41 AM in reply to: LisaDrago
Hi Lisa,
A few things to check:
1.  There is only one void in the family correct?  An overlapping second void would display similar to your image.
2.  Does the void display in the project as well after you load the family in?
3.  What happens if you manually use the Cut Geometry tool between the void and the extrusion; does it stay visible?
Thank you,
Ryan Duell
Revit Clinic
@revitclinic
LisaDrago
Message 3 of 3 (292 Views)
03-01-2011 04:58 AM in reply to: LisaDrago
Sorry it took so long to come back to this...
So when i ppull it into a project it goes away... so i don't think it is a huge problem - just really kind of weird...
Thank you for your help.
LD
