Hi
I am unable to visulize the projection line of fabric sheet in section view. However, the cut lines are visiual.
Any thoughts how I can make them visiable?
Hi. Change your detail level to Fine and your visual style to Hidden. That should do the trick.
If this solves your problem please Accept As Solution.
I am using both fine and hidden in the picture included earlier ( I guess I shoould have mentioned that)
Any other suggestions?
Hi. I can't really say what is happening unless I see the model. Try attaching it so that I can take a look.
Just a suggestion, make sure that your fabric reinforcement is existing and is passing through your section in the parallel direction.
