Revit Architecture
Active Contributor
2 Kudos
Post 11 of 15
Re: Visual depth in elevation
01-15-2013 05:14 AM in reply to: Alfredo_Medina
Ah yes, that makes sense of course. But then for roofs and possible other parts that spread and turn you could use the LW command and change line weight for those specific lines, right?
Might be as time consuming as the masses, but I just dont like the idea of having to add new elements, and hide/show different masses for different views to get the desired result.
*Expert Elite*
363 Kudos
Post 12 of 15
01-15-2013 05:18 AM in reply to: a06vsh
Well, yes, you could use the Linework tool, but that will take a lot more time than introducing some glass panels or masses. It's not ideal, but unless there is some specific tool for this, I think those methods are a good solution in the meantime.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Member
0 Kudos
Post 13 of 15
10-04-2013 10:56 AM in reply to: Alfredo_Medina
I have tried the process of using Mass object to reduce the blackness of the lines further away from the elevations view point, and that mass element in view category is selected to be halftone. By choosing it to be halftone you can use this method to work on Elevations and Sections, while also annotated. (as opposite to what you suggested in the first post).
But yes, Autodesk has to come up with a simple solution for this.
New Member
0 Kudos
Post 14 of 15
05-20-2014 02:04 AM in reply to: a06vsh
what if my elevations was curtain glass and  linked from another file ????
New Member
0 Kudos
Post 15 of 15
07-31-2014 02:35 PM in reply to: hassan.mashmoushy
What's wrong with using a View Template?
Is there a reason why that has not been suggested?
Post to the Community
New Post
