Is it possible for you to post the family file? Then perhaps someone can
trouble shoot the file itself to see what the issue might be.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
"caLayton" wrote in message
news:6304459@discussion.autodesk.com...
news:6304416@discussion.autodesk.com...
> Can anyone suggest the correct way to get the Visibility Settings to work
> properly?
here's an excerpt from:
Revit Architecture Families Guide (2010)>>Creating A profile Family
6. To specify the detail at which the profile family displays in the
project, select any of the lines of the profile sketch, and click Modify
Lines tab>Visibility panel>Visibility Settings.
7. Select the desired detail levels (Fine, Medium, or Coarse), and click OK.
Tip: You can specify the detail level for detail components using the same
methods.
Next, define the profile usage.
that's what I did,
but the Profile Lines are not responding to the detail level settings.
