Revit Architecture
Revit Architecture
Valued Contributor
RJK42
Message 1 of 2 (1,352 Views)
Vinyl Siding instead of Wood Siding/Clapboard
1352 Views, 1 Replies
12-12-2012 06:55 AM
I have created exterior walls with the appropriate material.  I need to include vinyl siding as my finished exterior side but can only locak "Siding, Clapboard" which is wood within the Material Browser.  Does revit have the option of vinyl siding?  Is there an extention, addon to install or is this something you would have to create??
See pic.
Thanks in advance!!
Alfredo_Medina
Message 2 of 2 (1,307 Views)
Re: Vinyl Siding instead of Wood Siding/Clapboard
12-16-2012 09:43 AM in reply to: RJK42
If a material is not there, you can create it, without the need of any add-in. Simply find the button to create a new material. Give it a name, define its graphic and material properties, done.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
