Views with visible transparency of Glass-Materials RAC 2013
4 REPLIES 4
9521 Views, 4 Replies
Hi!
We would like to make the transparency of glass-materials visible in views and section-views by using the "realistic style".
During a 3d-view our glass-material looks like transparent.
Isn't it possible for REVIT to display the transparency of materials in views ?Smiley Frustrated
The workaround to hide "glass" by using "overriding visibility" is not possible for us because some of our families and project families are using glass-materials inside (Showcases f.e.).
Thank you in advance,
Bernhard
Software (German) :
RAC 2012+2013
Inventor Pro 2013
AcadM 2012
MaxDesign 2013
Sketchup 8 Pro
4 REPLIES 4
Alfredo_Medina
@Anonymous wrote:
Hi!
We would like to make the transparency of glass-materials visible in views and section-views by using the "realistic style"...
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Hi Alfredo,
Thank you for your reply.
Your suggested solution is not possible to us.
There are two reasons:
1) If you use a "window family" it is not possible to select the glass separately.
So the frame would also shown as transparent.Smiley Frustrated
2) If you use a project family it is not possible to select some enclosed items separately.Smiley Mad
For window- and facade-families we use the hide option inside the "overriding visibility menue" (deselect glass f.e.)
Kind regards,
Bernhard
Alfredo_Medina
Yes, you would need to make some changes to the windows if you want to do this. There are at least two options:
  1. Use windows with shared nested families for the panels. By doing this, the panels could be selected independently from the frames, and then you could make the panels transparent.
  2. Use embedded curtain wall elements instead of windows. Then, select the panels and make them transparent, as in the illustration above.
Hi Alfredo,
for now I have a other solution:
We will use the "Override Graphic in View" and  change the surface transparancy only onto 1% !
This has affect only to the transparancy (of material with transparancy).
This works also with project families.
Revit is a crazy program 😉
Bernhard
Rail Community
