Viewport Scales
1 REPLY 1
tstewart
432 Views, 1 Reply
Viewport Scales
I can't change the scale of a dwg. on a sheet. Can you uggest what I need to do?
Tags (1)
1 REPLY 1
AJA14
in reply to: tstewart
Hi.
If you have a view template assigned to the view then you can't change it. You have to either change the scale from the viewport, or remove the assigned viewport and then apply your changes manually.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
