Show only
Search instead for
If you have a view template assigned to the view then you can't change it. You have to either change the scale from the viewport, or remove the assigned viewport and then apply your changes manually.
Ali Al-Hammoud Structural Design Engineer MZ & Partners Engineering Consultancy
