Viewport extensions
4 REPLIES 4
alex60
576 Views, 4 Replies
Viewport extensions
Hi every one, I am using Revit 2012 and am having an issue with the viewport on a sheet. When I hover the viewport I can see a border that is not the viewport extensions in the view.  I tried to reduce the crop view and the annotation crop but it doesn't affect the border in the sheet. Does any one know how to reduce this border? See the attached image.
Thanks in advance.
4 REPLIES 4
jim5552
in reply to: alex60
I think the size of your view port is determined by the reference plane in your view. Play with the length of the reference plane and see if that does anything to your view port size.
alex60
in reply to: alex60
Hi, there is no any reference plane in my drawing. It is a callout to make a detail, so I don't have any reference plane.
Thnaks, Alex
mike
in reply to: alex60
I think the previous answer was refering to the horizontal dashed green line.  This looks like a reference plane or reference line, which will affect the viewport size.
Cheers.
alex60
in reply to: mike
Thank you very much, it worked.
Alex
Rail Community
