View Title Tags - National CAD Standards 4.0
3 REPLIES 3
aturner77
2008 Views, 3 Replies
I need to make View Title Tags in Revit Architecture 2011 that match the National CAD Standards 4.0. This means the bubble is on the right side. Also for plans the North Arrow is on the right side. I want the bubble and North Arrow to be able to move with the node for the View Title Tag line. I have attached a JPG file of each View Title Tag I am referring to.
3 REPLIES 3
in reply to: aturner77
That is not NCS 4.0 compliant. The NCS has it on the left hand side, because we read text from left to right. That is how Revit works also.
aturner77
I should have mentioned that the client standard addendum modified the block to put the bubble at the end. So I still would like to know if there is a way to shift the bubble.
OK you can make a tag like this. Look into the view tag family. The only problem is Revit's view titles are really only setup to expand with the width of the view from left to right. If you make one that reads right to left, you have to make them fixed widths in order to force the bubble to the right. In this case you end up making different widths for different sizes of views. I usually make them type based.
