I would like to have two different layouts of my site plan. One is existing and does not show any of the new construction. The other is a complete view of the project. Is there a way to keep the existing site plan dependent while turning off the new construction to show only the previous + demo? If I set up a view template I cannot alter in the dependent view to make the changes that I want as options are greyed out. Is the only way to do this to create them as independent views?
Solved by CoreyDaun. Go to Solution.
Dependent Views share the same Visibility Settings ** as their parent Views, which is why they are Dependent Views. So yes, you will have to make them Independent Views if they will have differing Phase and/or Phase Filter Settings. Is there a particular reason that you'd prefer to keep them as Dependent Views?
Edited: removed the ** above about View Scale. View Scale is shared, too.
Thanks for the quick reply. I wanted to keep them dependent because I'm a dork and sometimes remember something later that I forgot something and it usually makes it easier to have one master plan that I work on. It's not a huge deal but would have made life a little simpler. Thanks for the help.
