Revit Architecture
Rebel1
Message 1 of 4 (258 Views)
Accepted Solution
View Range
258 Views, 3 Replies
08-31-2012 12:50 PM
How do you set the view range to show a window with a sill height of 5'-0" and a dog door with a head height of 2' in the same wall on a floor plan view?
Hi
You can either draw from a View Renge.
Using the following procedure:
1 - The ribbon view of the panel, create a list of open plane view and select the option to view renge.
2 - Now, using the drawing tools in a Sketcch depending on the desired position draw.
and Click Finish
For example, on Windows.
3 - view Renge select and click on icon to view renge window content
cut plane to the desired value can be changed and Ok.
Thanks, this works great.
Valued Mentor
gh_ar
Message 2 of 4 (249 Views)
Re: View Range
08-31-2012 03:23 PM in reply to: Rebel1
Hi
and Click Finish
Rebel1
Message 3 of 4 (197 Views)
Re: View Range
09-04-2012 04:25 AM in reply to: Rebel1
MikeMaloney
Message 4 of 4 (193 Views)
Re: View Range
09-04-2012 04:27 AM in reply to: Rebel1
If these are "One-Off"  isolated incidents, I'd use "Plan Regions"
Mike
Mike Maloney
BIM Design Automation Coordinator
CH2M Hill
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
