Okay - so I have small windows located at different hts on the same floor plan. If I set the cut plane to 4'-0" I can see 1 window, and if I set it to 6'-0" I can see 2 other windows, but not the first one. There is no elevation ht where all the windows can be cut thru. Is there a way to view windows below or above without moving the windows into the cut plane?
