How would I set up a view filter so only curtain walls are showing. Thew will not show up if walls aren't also checked, but I don't want the walls, just the curtain walls. Thanks.
I would probably do it like in attached screenshot.
Make a filter which filters "basic walls". Than in the view(s) add the filter an set visible to off.
Off course things might differ for you depending on your project setup.
Louis
Please mention Revit version, especially when uploading Revit files.
No that would not solve the question asked. The question was to show curtain walls but hide the other walls.
If you turn off the visibility in the wall model category all walls, including the curtain walls, will be hidden.
Louis
