Im trying to hide elements on my level 0 plan by changing the view depth in the view range settings, however objects which are below the level i am setting are still visible. Anybody know what im doing wrong, or is there an easy way around this??
A few items to check or keep in mind:
1. Verify if the View Properties > Underlay is set to a level. If so try setting > None to see if the elements are still visible.
2. Some component categories react differently to the view range and cut plane. I have included a blog post below with additional information:
http://revitclinic.typepad.com/my_weblog/2010/02/component-families-above-the-cut-plane.html
3. Some categories of elements such as floors, will show as long as they are within 4’-0” of the View Range > Bottom. If you are seeing this behavior with floors, or have plan regions in the view, please keep this post in mind:
http://revitclinic.typepad.com/my_weblog/2010/03/floors-and-plan-regions-and-view-range.html
4. Lastly, if you are seeing walls with similar behavior verify the walls do not fall into the “low wall” category:
http://revitclinic.typepad.com/my_weblog/2010/07/cut-behavior-of-low-walls.html
Please let us know if the issue should persist.
Thank you,
