I am trying to convert a Revit drawing to AutoCAD, but a specific cross section is missing about 1/3 of the information in the cross section (compared to the PDF that the architect send us). Turns out the 1/3 that is missing (the reinforced conrete risers) is exactly what our engineer needs to reference. I thought that it may be that the risers are hidden in the view, however I clicked on the lightbulb at the bottom of the screen, and there is nothing hidden (at least, nothing shows up to select for "unhiding").
I'm an "AutoCAD guy" still, and this seems to be a very simple thing, so I'm hoping to hear (read) back from someone soon.
Thank you so much in advance.
can you be more precise?
Where is missing 1/3 ? in exported AutoCAD or in Revit ?
1/3 is a part of the drawing or part of the total elements on the screen?
Can you send a screen shot?
If what is missing is in Revit and represent a category of objects , then try this:
in the View with problems with nothing selected : Properties > Visibility Graphics Overrides > verify Model Categories and Annotation Categories >Visibility...could be unchecked entities that you need
Agreed - we need more information...
Do you have a view in Revit setup already with the information showing?
You can export the view to AutoCAD in the Application menu>Export>dwg
LD
