Vertical Dimension
4 REPLIES 4
tonkata
1162 Views, 4 Replies
Vertical Dimension
Is there any way to rotate a dimension vertically?
4 REPLIES 4
LisaDrago
in reply to: tonkata
Currently - No there is not an option.
You could replace the dim text with opaque text but that can get very messy and double the work.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
tonkata
ah ok I see.... so there's no way of creating a custom dimention similar to a family?
LisaDrago
Dimensions are completely controlled by Revit.. I have attached an image for reference.. You can control the read conversion but vertical is not in there..
So you are pretty stuck on this one.
LD
lmorales
10 years later... how is this STILL not an option?!
Autodesk - help us out! -- Add 'Vertical' to 'Dim Text Reading' orientation.
