variable width generic wall?
13 REPLIES 13
Message 1 of 14
992 Views, 13 Replies
ADT user evaluating Revit here...
Can one create a variable width wall in Revit?
I see an extensive list of OOTB 'Generic' Wall Types,
all width specific.
Examining the settings in 'Edit Assembly'
I don't see a way to define a variable width for a Layer.
Just confirming...
13 REPLIES 13
Message 2 of 14
Variable so you can just select it and "stretch" to a new width somewhat
randomly? No. But its very easy to edit a wall type, click the
Duplicate/New button to make a new wall type and change the width in the
Edit Assembly area.
My office has created a "standard" wall tyes file in which we have created
over 50 types of walls that are all real world dimensions and easy copied
into projects for use.
"Corey A. Layton" wrote in message
news:5349255@discussion.autodesk.com...
all width specific.
Just confirming...
Message 3 of 14
> somewhat randomly?
not exactly. well, kindof...
One that you can edit the width of Layer(s) per instance,
without changing Type.
my first day into it,
and I'm already trying to ADT-ize Revit. 😞
> the Duplicate/New button to make a new wall type and change the width
> in the Edit Assembly area.
> created over 50 types of walls that are all real world dimensions and
> easy copied into projects for use.
I'm worried about a *very* long listing of generic Wall Types to describe
the various
conditions I encounter with renovation projects. A single Type, with
wariable width
setting per instance is much more simple and efficient....
Message 4 of 14
yes, totally agree! I've requested that the next version of Revit allow
"sub-types" for walls so I could define wall type "A", and then have several
widths for that definition.
But you are correct now...one new type for every width, even if it is just a
simple gyp board wall, with a 2x4, or 2x6, or 2x8 core....this list does get
L O N G!!!
news:5349322@discussion.autodesk.com...
> somewhat randomly?
the various
wariable width
Message 5 of 14
"Scott Davis" wrote in message
news:5349303@discussion.autodesk.com...
>I've requested that the next version of Revit allow "sub-types" for walls
>so I could define wall type "A", and then have several widths for that
>definition.
glad to see someone's all over it...
Message 6 of 14
wow.
lineweights.
that's somethin', eh?
a numeric placeholder of (potentially) variable width(s) that is output
scale dependent.
*nice*...
Message 7 of 14
news:5349594@discussion.autodesk.com...
ok, I just changed the scale of an annotated plan View.
that's friggin' *cool*.
There's definately some very particular content placement quirks,
And I'm beginning to realize the breadth of settings one must comprehend
to divert from OOTB;
but this is allright.
you folks are just going to have to bear with me for a few days.
I'm takin' the red pill...
Message 8 of 14
Reminds me of an old cigar commercial ..."Sooner or later, we're gonna getcha!"
(I think it was Benson & Hedges and featured Jackie Gleason?)
Message 9 of 14
There seems to be a very apparent shift in Revit-based discussions over in
the ADT discsussion group as of late.
I'm not sure what prompted it,
by a lot of the competitive negativity is waning...
> gonna getcha!"
"You can call me Ray, or you can call me Jay, but you doesn't have to call
me Johnson."
cheers....
Message 10 of 14
ahhh...a Phase One Revit newbee:
Phase One - Initial Excitement!!!
"Holy ****! Look what I can do with this thing!"
Here's the Six Stages of a Revit user for your enjoyment:
http://forums.augi.com/showthread.php?t=3335
news:5349625@discussion.autodesk.com...
Message 11 of 14
thanks.
Phase Six - Zen of Revit
"You have a template to beat all templates."
I'm starting to realize that this is paramount.
Message 12 of 14
is anyone there yet???
Brian Earsley
www.arete3.com
708.342.1250 x.225
New to DWF? Check it out!
http://www.arete3.com/services/communication.html
select "ARCHITECTURE" - "File Formats"
news:5350341@discussion.autodesk.com...
thanks.
Message 13 of 14
cprettyman
So, I have an existing condition that is a 400 year old stone and adobe building, with no two walls the same thickness, and several walls that vary in thickness along their length. (I mention the agge because it's the 400 years worth of modifications, and additions that led to these conditions)
I can create a family for each and every existing wall, I suppose, but that's a little absurd.
what about the varying width along one wall?
Message 14 of 14
Don't use walls, use mass objects. You can vary each instance.
cganiere
