I got a custom door I downloaded and brought in but I can figure out how to use it. Its not showing up when I click on the create door command I tired inputing the width height in the properties and that didnt make a difference. Still learning...
Hey badincite
You have downloaded a CURTAIN WALL DOOR, this is just a modified curtain wall panel to look like a door. You will not find it on your Door type selector. Assuming you did not mean to download a curtain wall door, you will need to download a different one as you cannot use this (without some fudging 🙂
If you did mean to download a curtain wall door, draw in your curtain wall, select one of the panels, UNPIN it and change it to the door you downloaded.
The Width/Height parameters do nothing in the type properties of a curtain panel, the Grid lines of the curtain wall control the width & Height.
Hope this helps 🙂
Didnt really mean to download it that way but it will work thanks! Where can I get a actual good commerical door family from?
