user materials
2 REPLIES 2
ea/a
398 Views, 2 Replies
user materials
How does one get their user materials from an old version of revit into the latest upgrade?
I recently opened an older model in a new version of revit and lost all the user defined materials. What is the easiest way to retrieve these lost materials?
2 REPLIES 2
in reply to: ea/a
Make sure the library that holds the materials is referenced by Revit. You'l lfind this under Settings>Options and then the rendering tab.
in reply to: ea/a
Either add a new path to your existing Users milb directoty, or move your user mlib to the default path location. "Peter Jackson" wrote in message news:4002f1b8_3@statler... > Make sure the library that holds the materials is referenced by Revit. > You'l lfind this under Settings>Options and then the rendering tab. > >
