Upgrade file from 2013 to 2014: unrecoverable error
1 REPLY 1
wblaney-cda
734 Views, 1 Reply
I have a relatively small model (20MB) that is causing R2014 to crash during the upgrade process. I have stripped out any extra views, model elements materials etc. and purged until there's nothing extra left. Checking the journal after the crash didn't yield any corrupt object ID's that I could select and delete from the 2013 file. the one ID that seems to be causing the problem "can't be selected in this mode" when I try to select by ID.
Below is the section of journal from the file upgrade lines through the crash:
' 6:< Your file is being upgraded to the latest file format. Please be patient. Once the process is completed and the file is saved you will no longer experience upgrade related slowdown.
' 7:< Current project ADocument version:2655
' 8:< ::3:: Delta VM: Avail -49 -> 8386714 MB, Used +54 -> 565 MB, Peak +54 -> 566 MB; RAM: Avail -58 -> 6305 MB, Used +58 -> 657 MB, Peak +59 -> 657 MB
' 7.079370!!!!!!!!! 8:!!!BIG_GAP ADocumentUpgrade::docUpgrade
' 0.057318 9:<<<updating dependencies in delayed deletion
' 0.002111 9:<<<getAllNonexistentParents in delayed deletion
' 8:< ::3:: Delta VM: Avail -24 -> 8386690 MB, Used 565 MB; RAM: Avail 6305 MB, Used 657 MB
' 0.022750 9:<<<findAppInfoNonexistentParents in delayed deletion
' 0.002767 9:<<<pADoc->deleteElementsAndChildren in delayed deletion
' 0.021385 9:<<<debug check findAppInfoNonexistentParents in dp
' 0.106944 8:<<delayed deletion
' 7:< Unnecessary nesting;n:\build\2014_ship_x64_inst_20130709_2115\source\revit\revitdb\document\ADocumentUpgrade.cpp;1897;ID_REVIT_FILE_OPEN ;N++E(N);
'11:< ::3:: Delta VM: Avail -68 -> 8386622 MB, Used +55 -> 620 MB, Peak +54 -> 620 MB; RAM: Avail -52 -> 6253 MB, Used +52 -> 709 MB, Peak +51 -> 709 MB
'11:< FaultyAtomsCheckLog - Comparasion difference found :
'11:< Change behavior of room warnings
'14:< REGEN_DOC_CONTEXT_INFO: Known attempt to modify wrong element during regeneration
'19:< REGEN_DOC_CONTEXT_INFO: Changing wrong atom in regeneration
'11:< FamSymStretching: stretching 2602633 from 2602569
'13:< DBG_INFO: Inactive symbol in getOrigin: line 446 of Elem\FamilySymbol.cpp.
'C 21-Oct-2013 11:11:49.631; 12:< Assertion failed: line 247 of Elem\FamSymGNodeStretcher.cpp
'C 21-Oct-2013 11:11:49.756; 9:< System exception in ADocument::regenerate
'C 21-Oct-2013 11:11:49.757; 9:< executing step: GeomStep of FamilySymbol {2602633} (1: BaseFamilySymbolGStep)
'C 21-Oct-2013 11:11:49.757; 9:< element 2602633 of type FamilySymbol
' 9:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 9:< RAM Statistics: 6251 / 12265 711=InUse 712=Peak
' 9:< VM Statistics: 8386622 / 8388607 620=InUse 621=Peak
' 9:< 000000000FD1FA10 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FA38 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FA60 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FA88 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FAB0 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FAD8 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FB00 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< 000000000FD1FB28 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
' 9:< Exception occurred
'C 21-Oct-2013 11:11:49.765; 9:< ExceptionCode=0xe06d7363 ExceptionFlags=0x00000001 ExceptionAddress=000007FEFDFE940D
' 9:< RAM Statistics: 6250 / 12265 712=InUse 712=Peak
' 9:< VM Statistics: 8386623 / 8388607 620=InUse 621=Peak
' 5.723351!!!!!!!!!!!10:!!!BIG_GAP ;PERF;MISC;regenerating
' 0.000017 11:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.025989 10:<<EndOrAbortUndoTransaction();DOPT;
' 9:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 9:< ::3:: Delta VM: Avail -17 -> 8386606 MB, Used +0 -> 621 MB, Peak +1 -> 622 MB; RAM: Avail -4 -> 6250 MB, Used +3 -> 712 MB, Peak +4 -> 714 MB
'E 21-Oct-2013 11:11:53.191; 9:<
Jrn.AddInEvent "AddInJournaling" , "MessageBox(OK,Revit).Click(Cancel)"
'H 21-Oct-2013 11:11:53.206; 9:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 21-Oct-2013 11:11:53.206; 9:< program terminated
Any assistance would be appreciated! If you want the whole file, I can send an FTP link bby PM.
Wes
1 REPLY 1
Lance.Coffey
in reply to: wblaney-cda
If the element ID of the problematic element (2602633) can't be selected through the UI, try taking a copy of the project, and remove everything from it (including all views except for the default 3D view, and all of the model geometry). If the emptied project can be upgraded, you should be able to narrow down the specific element or elements causing the error during the upgrade process.
Lance Coffey
Technical Support Specialist
