need more info on your process and model.
revit version?
are there certain sheets giving you trouble? (round, curved, radius geometry
can increase output time greatly for some views)
your post reads "publish" but the forum is Revit Building not ADT or ACA.
are you printing to dwf or exporting to 2D dwf?
if printing, are you using the latest windows dwf driver?
is this the only project you have this trouble with?
if printing to dwf, what are you settings?paper size, quality, raster or
vector???
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
New to DWF? Check it out!
http://www.arete3.com/services/communication.html
select "ARCHITECTURE" - "File Formats"
wrote in message news:5485370@discussion.autodesk.com...
Hello. Anyone know a reason for this unrecoverable error to come up whil in
the middle of publishing a project to a .dwf? Our project BIM is about 100
MB in case that helps. All new Dell Dimension 9200 machines. 3 of us have
tried it with the same results. We can group the project into 20 or so
sheets to one publish command, but what a pain. We would rather be able to
send all sheets to publish to .dwf. Any help is muchly appreciated!
