I just did a test on this and pinned 2 walls using PP, then selected both of
them and I typed in UP or you can go to the Edit menu and select Unpin
Position. What type of elements are you having trouble with?
"R Dias" < wrote in message
news:5527494@discussion.autodesk.com...
Is it possible to unpin multiple elemente in one operation? I've never found
this option which means everytime I need to unpin multiple elements, I need
to unpin one by one. Which is tedious, if not time consuming.
R Dias
