My REVIT from Design suite 2013. It cannot recognize correctly video card which is a certified hardware, NVDIA Quadro K1000M. I have installed card driver from Autodesk web as well.
Any setting in REVIT to tweak?
screen shot of warning message attached.
Solved by DarrenP. Go to Solution.
are you having problems with revit performance because of this?
if not you can ignore that message
mine says the same thing but i am not having performance issues with revit so i just ignore it
DarrenP
