I suddently can't open Revit 14.
I run windows 7 32 bit and it was workin yesterday. Can anyone help me?
Here is the journal Revit is refering to:
' 0:< Initial VM: Avail 1855 MB, Used 55 MB, Peak 55; RAM: Avail 1118 MB, Used 70 MB, Peak 55
'C 24-Oct-2013 15:48:50.819; 0:< started recording journal file
' Build: 20130722_2115
Dim Jrn
Set Jrn = CrsJournalScript
' 0:< ->desktop InitApplication
' 0:< <-desktop InitApplication
' 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Metric Library=C:\ProgramData\Autodesk\RVT 2014\Libraries\US Metric\,Metric Detail Library=C:\ProgramData\Autodesk\RVT 2014\Libraries\US Metric\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -27 -> 1829 MB, Used +7 -> 63 MB, Peak +7 -> 63 MB; RAM: Avail -14 -> 1105 MB, Used +11 -> 82 MB, Peak +11 -> 82 MB
'C 24-Oct-2013 15:48:51.506; 0:< License initialization complete
' 0:< ::0:: Delta VM: Avail -451 -> 1378 MB, Used +225 -> 288 MB, Peak +225 -> 289 MB; RAM: Avail -186 -> 919 MB, Used +248 -> 330 MB, Peak +248 -> 330 MB
' 0:< Autodesk Revit 2014
' 0:< 32-bit load point = C:\Program Files\Autodesk\Revit 2014
' 0:< this journal = C:\Users\hp\AppData\Local\Autodesk\Revit\Autodesk Revit 2014\Journals\journal.0065.txt
' 0:< ::0:: Delta VM: Avail -37 -> 1342 MB, Used +11 -> 300 MB, Peak +29 -> 318 MB; RAM: Avail -16 -> 904 MB, Used +15 -> 346 MB, Peak +16 -> 346 MB
' 0:< Journal Init
' 0:< Log Summary
' 0:< .Count
' 0:< ...CloseHiddenWindowsInAllDocuments = 1
' 0:< ...onUpdateWindowCloseHidden = 1
' 0:< ...ProjectRecsCreated = 1
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 21
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 4
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< ...Global = 2 (SizeSegregating)
' 0:< ...PoolGlobal = 1 (Pool)
' 0:< ...PoolLocking = 1 (Locking)
' 0:< ...PoolScalable = 1 (Pool)
' 0:< ...PoolTreeNodes = 0 (Allocator)
' 0:< ...Scalable = 0 (Scalable)
'H 24-Oct-2013 15:49:06.510; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\Denmark\Construction-DefaultMetric.rte, Architectural Template=$AllUsersAppData\Templates\Denmark\DefaultMetric.rte, Structural Template=$AllUsersAppData\Templates\Denmark\Structural Analysis-DefaultDNKENU.rte, Mechanical Template=$AllUsersAppData\Templates\Denmark\Mechanical-Default_Metric.rte"
'H 24-Oct-2013 15:49:06.511; 0:<
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2014.000", "2.143"
Jrn.Directive "Username" _
, "hp"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
'H 24-Oct-2013 15:49:06.512; 0:<
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 1
Jrn.Directive "AllowPinnedSelection" _
, 1
' 0:< API_SUCCESS { Registered an external service.: ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2); VendorId(ADSK); Description(Navisworks Export Service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143); VendorId(ADSK); Description(The external service to view and modify code checking parameter in analytical elements.) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc); VendorId(ADSK); Description(IFC) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); Name(Default IFC); VendorId(ADSK); Description(Default IFC) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942); VendorId(ADSK); Description(IFC) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); Name(Default IFC); VendorId(ADSK); Description(Default IFC) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); VendorId(ADSK); Description(Duct fitting and accessory pressure drop service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); VendorId(ADSK); Description(Pipe fitting and accessory pressure drop service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); VendorId(ADSK); Description(Duct Straight Segment Pressure Drop Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); VendorId(ADSK); Description(Pipe Straight Segment Pressure Drop Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(bf0da776-5307-4747-8285-f358e92a90d0); VendorId(ADSK); Description(Convert Fixture Units to Flow for Plumbing Fixtures, which is applicable to Domestic Water System Flow Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); VendorId(ADSK); Description(Duct fitting and accessory pressure drop UI service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); VendorId(ADSK); Description(Pipe fitting and accessory pressure drop UI service) }
' 0:< ::0:: Delta VM: Avail -44 -> 1298 MB, Used +10 -> 311 MB; RAM: Avail -16 -> 888 MB, Used +15 -> 361 MB, Peak +15 -> 361 MB
'C 24-Oct-2013 15:49:07.157; 0:< Assertion failed: line 509 of ADynamicLinkLibrary.cpp
' 0:< Exception occurred
'C 24-Oct-2013 15:49:07.163; 0:< ExceptionCode=0xe06d7363 ExceptionFlags=0x00000001 ExceptionAddress=75D5969B
' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 0:< RAM Statistics: 889 / 3055 360=InUse 361=Peak
' 0:< VM Statistics: 1300 / 2047 310=InUse 318=Peak
' 0:< Unconverted MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 0:< ::0:: Delta VM: Avail -21 -> 1278 MB, Used +1 -> 312 MB; RAM: Avail -2 -> 887 MB, Used +2 -> 364 MB, Peak +2 -> 364 MB
'H 24-Oct-2013 15:49:10.589; 0:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 24-Oct-2013 15:49:10.590; 0:< program terminated
Hello and Welcome to the Discussion!
Have you tried un-installing and reinstalling Revit?
Here is how you can do a clean uninstall >HERE<
That is where I would start.
LD
