I had the same problem,tanx
@Anonymous wrote:
If it is demolished it should be still listed as Phase Created - Existing
and phase Demolished as New Construction. The existing door should be
visible in an existing view. If you are trying to remove it from being
demolished you will have to select it then in properties change the Phase
Demolished setting to none and the Phase Created will remain as Existing.
"jreyhons" wrote in message news:6300588@discussion.autodesk.com...
> I demolished an existing door on my project that is now not getting
> demolished. How do I change it back to the existing phase? In the element
> properties the phase is grey and cannot be changed. Please help.
> Thanks.
