Hi everyone
I want to show a linked view from another proyect that has an underlay ceiling plan,I'm using By linked view option to show exactly the same view from the original project but the underlay RFP doesn't appear. I just want to show the outline of some skylight diffusers from the ceiling plan
Please check the images attached
Solved by rosskirby. Go to Solution.
You can't show underlays from linked files. This is a known limitation, and there is no known workaround (that I'm aware of).
