uncut geometry totally bugged in Revit
4 REPLIES 4
cekuhnen
583 Views, 4 Replies
so I select uncut geometry
select the solid
select the void
solid disapears
void is left
that is such a repetative result it makes me wannt throw Revit out of the window...
is there anyway to make the now invisible to deleted solid apear?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
4 REPLIES 4
Lance.Coffey
in reply to: cekuhnen
I believe I can reproduce what you are seeing, but it seems to be dependent on the shape of the solid/void.
If it’s the same issue I’m seeing, changing the Detail Level clears the issue (as well as closing and reopening the file).
Lance Coffey
Technical Support Specialist
Lance.Coffey
in reply to: Lance.Coffey
If the issue you are seeing is the same as the one I reproduced, then this has been logged with our developers, and you can restore the display by changing the detail level (and then back).
Lance Coffey
cekuhnen
Let me give this a try!
Claas Kuhnen
eecenarro
Thank you very much!!! This solved my problem.
Rail Community
