I'm a part of a small firm and we're about to be at "all hands on deck" status in order to meet an upcoming deadline. We've used worksharing on other projects but have had quite a bit of trouble not stepping over one another with edit requests - we are a collaborative firm with too few people to divide responsibilities into "shell", "interiors", etc. Everyone kind of works on everything.
With regards to our upcoming deadline, the model itself should not change too much (though it may change), most of the work will be in detailing distributed amongst seven people (each responsible for certain sheets), and there will be new views created here and there. My question is, does anyone know of a good strategy for managing this kind of workflow (with tight deadline and little room for technical glitches) so that everyone has access to the most current model, can work on their respective sheets/tasks, and can get those back into one model for printing/compiling?
Thanks in advance
To add to what Damo3 already said, I would add that some brief game-planning each day to delineate specific tasks could help. You could break it up by view type (wall sections, section details, plan details, interior elevations, exterior elevations, floor plans, etc.) or by task (notes, dimensions, detailing [linework, filled regions, and everything needed to make the detail "look" right], sheet setup, schedules). Either way, each person needs to have a type of work that they are uniquely responsible for. You don't want to have two different people working on the same view, especially with annotation, because when you're creating something (i.e. notes, dimensions, etc.), there's no way for the other team members to know that it has been done until they sync. Then you're left with a lot of overlapping/duplicate info. Bad business.
Also, if you've got half a dozen people working on a single file, you're going to have problems when it comes to syncing. What I'd recommend is assigning a certain time to each person (i.e. 5 minutes past the hour, 10 minutes past the hour, etc.), so that no two people are trying to sync at the same time.
Yeah, worksharing is great in that you don't really have to deal with a hundred files for a single project anymore, but it still has its limitations, and nothing beats a good solid team meeting with clear roles and responsibilities to ensure the CDs go smoothly.
Good luck!
