theres probably some symbolic lines drawn in floor plan view. delete those
and you should be fine. but why don't you use the openings command rather
then faking a door?
wrote in message news:5454758@discussion.autodesk.com...
I am trying create an uncased opening family. I opened the cased opening
family did a save as and removed the trim. The openings look fine in
section/elevation but in plan the trim is still showing up, any ideas?
