Unable to share Shared Parameter txt file
8 REPLIES 8
Message 1 of 9
LisaDrago
1804 Views, 8 Replies
Okay - I have been making and sharing shared parameter files for years... For some reason today a co-worker's shared parameter file is invalid or could not be read - image attached...
We have run a couple of tests - I can create one on my computer and send to her without any issues... Any that she creates and sends to me - is invalid... WHY???
I made sure she has all the service packs and all that - so I am really at a loss..
Any ideas?
I will attach one of the test.txt files..
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
8 REPLIES 8
Message 2 of 9
CoreyDaun
in reply to: LisaDrago
Are both you and your co-worker running the same version of Revit? Was the Shared Parameter file added to with a newer version of Revit? If a Shared Parameter was added to the file as a type that did not exist prior to that release, the file will be reported as 'invalid' by previous versions.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 9
LisaDrago
in reply to: CoreyDaun
Yes - we are on the same version. We are both on 2013... That is why the invalid statement is baffling me...
LD
Message 4 of 9
CoreyDaun
The problem appears to be with the file itself - I was unable to directly link your file, but I could Copy/Paste that exact text into a new .txt file and it worked. I even tried copy/pasting the contents my shared parameter file (which I know works) over the text in yours, and it still returned the error. I, unfortunately, do not know of a solution to this aside from attempting a reinstall. Perhaps there is an add-on that could be inadvertently causing this? Do you have any installed that your co-worker does not?
Message 5 of 9
LisaDrago
Sure enought that worked!
That is really odd though... will have to consider reinstalling.
I have a lot of the extensions from the subscription center installed and an FM:Systems... She does not have any.
Thanks for your help!
LD
Message 6 of 9
dhurtubise
Did you check the .txt file encoding?
Message 7 of 9
LisaDrago
in reply to: dhurtubise
How do you do that?
LD
Message 8 of 9
dhurtubise
Save as and look at the encoding
Message 9 of 9
abodley
What should the encoding setting be?
I am having the same issue as LisaDrago...same exact error. Also tried to copy/paste into a new .txt but that did not work either.
See attached resultant .txt files.
Thanks so much for the advice.
